Invalid access to memory - _conf_get_bool
jstankiewicz@...
Whenever connecting to SCP on SolarWinds SFTP/SCP server.
WinSCP 5.17
Invalid access to memory.
(00BCC100) _conf_get_bool
(00F85D26) C5296_3
(00F87D8E) ____ExceptionHandler
(00F84B48) __ExceptionHandler
(00087D7F) ntdll.dll
(00073221) ntdll.dll.KiUserExceptionDispatcher
(00BD3F9C) _mainchan_new
(00BEB905) _ssh2_serverside_agent_open
(00BE9FAE) _ssh2_connection_new
(00BEA22C) _ssh2_connection_new
(00BFD05D) _ssh_ppl_free
(00BCBBE6) C2603_0
(00BCBCD9) _run_toplevel_callbacks
(00D06584) TSecureShell::EventSelectLoop
(00D05467) TSecureShell::WaitForData
(00D00425) TSecureShell::Init
(00CFFD65) TSecureShell::Open
(00D87CC5) TTerminal::Open
(00CBF943) TTerminalThread::TerminalOpenEvent
(00CBA8A0) TSignalThread::Execute
(000BBE7F) Userinterface::C20_0
(00015357) KERNEL32.DLL.BaseThreadInitThunk
(00066B72) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066B3F) ntdll.dll.RtlGetAppContainerNamedObjectPath
Using username "jstankiewiczadm".
Authentication failed.
Re: Invalid access to memory - _conf_get_bool
liberiaroleplay@...
Accès mémoire invalide - _conf_get_bool
WinSCP 5.17
Accès mémoire invalide.
Trace de la pile :
(00F85D26) C5296_3
(00BCBBE6) C2603_0
Log d'authentification (voir le log de session pour les détails) :
Utilisation du nom d'utilisateur "pa11tkj7.8b0934c5".
Erreur d'authentification
kvella@...
WinSCP 5.17
(00F85D26) C5296_3
(0008403F) ntdll.dll
(00071941) ntdll.dll.KiUserExceptionDispatcher
(00BCBBE6) C2603_0
(0001F417) KERNEL32.DLL.BaseThreadInitThunk
(0006562B) ntdll.dll.RtlGetAppContainerNamedObjectPath
(000655F8) ntdll.dll.RtlGetAppContainerNamedObjectPath
Using username "fmcscpbackup".
Access denied.
Thanks for your reports.
samang7317@...
WinSCP 5.17.1
(00BCC0A4) _conf_get_bool
(00F84E6A) C5296_3
(00F86ED2) ____ExceptionHandler
(00F83C8C) __ExceptionHandler
(00BD3F54) C2617_0
(00BEB8BD) _ssh2_serverside_agent_open
(00BE9F66) _ssh2_connection_new
(00BEA1E4) _ssh2_connection_new
(00BFD015) _ssh_ppl_free
(00BCBB8A) C2603_0
(00BCBC7D) _run_toplevel_callbacks
(00D05474) TSecureShell::EventSelectLoop
(00D04357) TSecureShell::WaitForData
(00CFF315) TSecureShell::Init
(00CFEC55) TSecureShell::Open
(00D86BB5) TTerminal::Open
(00CBE833) TTerminalThread::TerminalOpenEvent
(00CB9790) TSignalThread::Execute
(000BBE8F) Userinterface::C20_0
Using username "YARDINGS".
This is VMS Software, Inc. OpenVMS (TM) IA64 Operating System, V8.4-2L1
jean-jacques.galazka@...
WinSCP 5.17.1
Trace de la pile :
(00F84E6A) C5296_3
(00BD3F54) C2617_0
(00BCBB8A) C2603_0
Utilisation du nom d'utilisateur "jean-jacques.galazka@orange.fr".
Re: Accès mémoire invalide - _conf_get_bool
WinSCP 5.17.1
(00BCC0A4)
(00F84E6A)
(00F86ED2)
(00F83C8C)
(00BD3F54)
(00BEB8BD)
(00BE9F66)
(00BEA1E4)
(00BFD015)
(00BCBB8A)
(00BCBC7D)
(00D05474)
(00D04357)
(00CFF315)
(00CFEC55)
(00D86BB5)
(00CBE833)
(00CB9790)
(000BBE8F)
Using username "jean-jacques.galazka@orange.fr".
anusha.pallapothu@...
WinSCP 5.17.1
(00F84E6A) C5296_3
(0007E1AF) ntdll.dll
(0006BD91) ntdll.dll.KiUserExceptionDispatcher
(00BD3F54) C2617_0
(00BCBB8A) C2603_0
(00017492) KERNEL32.DLL.BaseThreadInitThunk
(000631C6) ntdll.dll.RtlAreBitsSet
(00063193) ntdll.dll.RtlAreBitsSet
Using username "rdongre".
254.ram@...
WinSCP 5.17.1
(00F84E6A) C5296_3
(00BD3F54) C2617_0
(00BCBB8A) C2603_0
Using username "user1".
frazel007@...
WinSCP 5.17.1
(00F84E6A) C5296_3
(0007E19F) ntdll.dll
(00BD3F54) C2617_0
(00BCBB8A) C2603_0
Using username "xxxxxxxxx".
Access is denied. See server logs for details.
earl.gangoso@...
Connecting to a Windows server installed with OpenSSH. I can connect to the server using Putty but not WinSCP.
WinSCP 5.17.1
(00F84E6A) C5296_3
(00084F0F) ntdll.dll
(000723E1) ntdll.dll.KiUserExceptionDispatcher
(00BD3F54) C2617_0
(00BCBB8A) C2603_0
(0001E987) KERNEL32.DLL.BaseThreadInitThunk
(00064DE2) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00064DAF) ntdll.dll.RtlGetAppContainerNamedObjectPath
Using username "Administrator-DN".
sascha@...
Zugriffsverletzung - ungültiger Zugriff auf den Speicher - _conf_get_bool
I right clicked a folder in a remote directory and selected "User commands for files > Tar/Gzip", because I wanted to zip that folder and download it. That's when the error occurred, and WinSCP asked me to report the error.
WinSCP 5.17.1
(00F84E6A) C5296_3
(00BD3F54) C2617_0
(00BCBB8A) C2603_0
Anmeldungsprotokoll (Siehe Sitzungsprotokoll für Details):
Verwende Benutzername "web26885834@alfa3212".
Anmeldung fehlgeschlagen.
jamesdaniel09874@...
WinSCP 5.17.2
(00BCC150) _conf_get_bool
(00F85292) C5296_3
(00F872FA) ____ExceptionHandler
(00F840B4) __ExceptionHandler
(00BD4000) _mainchan_new
(00BEB9F1) _ssh2_serverside_agent_open
(00BEA09A) _ssh2_connection_new
(00BEA318) _ssh2_connection_new
(00BFD149) _ssh_ppl_free
(00BCBC36) C2603_0
(00BCBD29) _run_toplevel_callbacks
(00D05668) TSecureShell::EventSelectLoop
(00D0454B) TSecureShell::WaitForData
(00CFF509) TSecureShell::Init
(00CFEE49) TSecureShell::Open
(00D86F65) TTerminal::Open
(00CBEA27) TTerminalThread::TerminalOpenEvent
(00CB9984) TSignalThread::Execute
Using username "dev.e07b67f6-231a-4182-9cfb-f463ddd02efc".
sascha@...
Re: Invalid access to memory when using File Custom Command --> Tar/Gzip
Hi Martin,
thank you for you e-mail. I downloaded the debug version and tried to reproduce the error.
This version, however, behaves differently.
When I right click a remote folder and select "File Custom Commands --> Tar/Gzip" I get the following error message.
The line obstructed by the error message is "Authenticating with pre-entered password." by the way.
Next, it says "Abnormal program termination" and WinSCP aborts (the stable version would stay alive after the error occurs).
kasem@...
WinSCP 5.17
(00F85D26) C5296_3
(00087D6F) ntdll.dll
(00BCBBE6) C2603_0
Using username "AE3PARFTP".
mick@...
The steps to reproduce were pretty basic. Opened a new SFTP session, was prompted for the password, clicked OK and it crashes. An FTP client that can't FTP... nice work.
WinSCP 5.17.2
(00F85292) C5296_3
(00BCBC36) C2603_0
Using username "itweb-user".
sam.niederriter@...
WinSCP 5.17.2
(00F85292) C5296_3
(00BCBC36) C2603_0
Using username "ftpuser".
etienne;ducamp@...
WinSCP 5.17
Trace de la pile :
(00F85D26) C5296_3
(00BCBBE6) C2603_0
Utilisation du nom d'utilisateur "administrator".
Accès refusé.
bin.chu@...
winscp as client login to Cerberus server with SCP protocol, always failed at first time with error message as below, reconnect will be successful in most of times, but flash quit sometimes as well.
But, same account as authentication, if shift to sftp, winscp works fine.
WinSCP 5.17.2
(00F85292) C5296_3
(0008252F) ntdll.dll
(0007008A) ntdll.dll.KiUserExceptionDispatcher
(00BCBC36) C2603_0
(000152C2) KERNEL32.DLL.BaseThreadInitThunk
(00060E37) ntdll.dll
(00060DFF) ntdll.dll
Using username "CofenseTriage".
awasson@...
WinSCP 5.17.2
(00F85292) C5296_3
(00BCBC36) C2603_0
Using username "bcg-paycom".
nA@...
Start connection to an OpenSSH on Windows (Server, installed from GitHub) via SCP mode, starts after veryfiying login data (bad user/password raises correct error; when using SFTP connection works fine).
WinSCP 5.17.2
(00F85292) C5296_3
(00BCBC36) C2603_0
Verwende Benutzername "someuser".
