Can I use session rawsettings shell option to change default shell AND alter sudo?
Ayudo98
US
I see it is possible to change the default shell Bash and also to alter the user I am logging in (known as su).
https://winscp.net/eng/docs/faq_su
https://winscp.net/eng/docs/ui_login_scp#shell
my question is: can I use both at the same time? if so, what is the syntax?
I currently using this:
$sessionOptions.AddRawSettings("Shell","/bin/ksh")
which works great.
I want to something like this:
$sessionOptions.AddRawSettings("Shell","sudo -s MyOtherUser")
If I add it two times, the system complains that there is a duplicate.
Regards, Raul.
