Server asks for authentication with a client certificate
tomino174
Czech republic
Hello, I have troubles with .NET library. I can successfully connect to ftp server and get files, but I when I use PutFiles method, I always get this message as output:
Error message: Server asks for authentication with a client certificate. Copying files to remote side failed. Failure reading network stream.
My session options were generated by WinSCP app.
                    Protocol = Protocol.Ftp,
                    HostName = ".....",
                    UserName = "....",
                    Password = "....",
                    FtpSecure = FtpSecure.Explicit,
                    TlsHostCertificateFingerprint = "................"
I really don't know, why is this happening. Any ideas? Thanks
PS: FTP user has full permissions, in FTP client I can upload files to the server without any problem.
Re: Server asks for authentication with a client certificate
What "FTP client"?
tomino174
Czech republic
What "FTP client"?
I'm using WinSCP client, it works without any issue.
  • log.txt (9.06 KB, Private file)
tomino174
Czech republic
OK, but the code is also using WinSCP.
Isn't it a different version?
I've just updated my client & .NET library via NuGet to the latest version. Behavior is still the same.
Please post a session log file both from WinSCP GUI and the .NET assembly.
