Keep up to date stuck on checking for changes
kalizi
Hi there,
I'm currently testing keepuptodate command in my local environment in order to deploy correct full command on a server and I got a problem with keepuptodate.
I'm on Windows 10 with "Xlight FTP Server" as test server, and I saved access as "test_local" on WinSCP (I know it's not a good practice but it's just a test)
The command i wrote in the shell is
WinSCP.exe test_local /Console /Script=script.txt
and the script.txt contains
option batch on
option transfer automatic
keepuptodate -delete F:\mirror_test /
close
But after launching the script, the console stuck on "Controllo modifiche nelle cartelle 1...", I have italian WinSCP so must be something like "Checking changes in folders 1...".
I also tried by logging the script with the
/log="F:\WinSCP.log"
option and here's the log
. 2020-03-08 15:07:06.590 --------------------------------------------------------------------------
. 2020-03-08 15:07:06.590 Using FTP protocol.
. 2020-03-08 15:07:06.590 Doing startup conversation with host.
> 2020-03-08 15:07:06.591 PWD
< 2020-03-08 15:07:06.690 257 "/"
. 2020-03-08 15:07:06.691 Getting current directory name.
. 2020-03-08 15:07:06.691 Startup conversation with host finished.
< 2020-03-08 15:07:06.691 Script: Sessione attiva: [1] anonymous@192.168.1.81
> 2020-03-08 15:07:06.692 Script: option transfer binary
< 2020-03-08 15:07:06.692 Script: transfer        binary
> 2020-03-08 15:07:06.693 Script: keepuptodate F:\mirror_test /
< 2020-03-08 15:07:06.693 Script: Controllo modifiche attivato, premi 'Ctrl-C' per interrompere...
< 2020-03-08 15:07:06.694 Script: Esplorazione sottocartelle di 'F:\mirror_test'...
. 2020-03-08 15:07:06.694 Keep up to date: Esplorazione sottocartelle di 'F:\mirror_test'...
< 2020-03-08 15:07:06.705 Script: Controllo modifiche nelle cartelle 1...
. 2020-03-08 15:07:06.707 Keep up to date: Controllo modifiche nelle cartelle 1...
. 2020-03-08 15:07:36.532 Sending dummy command to keep session alive.
> 2020-03-08 15:07:36.532 TYPE A
< 2020-03-08 15:07:37.032 200 Type set to A.
In my mirror_test folder I just have an image of 23KB and the root of my FTP it's empty.
Is there something I'm doing wrong?
