Notable to connect Network drive through winscp?
santosh
India
Hi..,
I have mapped network drive in windows server. Now when i connect through winscp software, i'm not able to see mapped network drive but i can see local drive. Please suggest the solution.
Reply with quote E-mail
Re: Notable to connect Network drive through winscp?
What protocol are you using? Can you see the mapped drive using any other client that uses the same protocol?
This is more likely a server-side configuration issue.
