Archiving on the remote site during download
Vann_the_Red
NC, USA
Good afternoon, all! I was adapting the script provided at: Moving local files to different location after successful upload
to download from a remote site and then archive to a different directory on that remote site. I'm uncertain, though, where the Session.MoveFiles call should live. Any advice would be greatly appreciated. Code below.
Regards,
VtR
param (
    $localPath = "C:\upload\*",
    $remotePath = "/home/user/",
    $backupPath = "/home/archive/"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "example.com"
        UserName = "user"
        Password = "mypassword"
        SshHostKeyFingerprint = "ssh-rsa 2048 xxxxxxxxxxx...="
    try
        # Connect
        # Download files, collect results
        $transferResult = $session.GetFiles($remotePath, $localPath)
        # Iterate over every transfer
        foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host "Download of $($transfer.FileName) succeeded, moving to backup"
                # Download succeeded, move source file to backup
                # Move-Item $transfer.FileName $backupPath
            $transferResult = $session.MoveFiles($remotePath, $backupPath)
            else
                Write-Host "Download of $($transfer.FileName) failed: $($transfer.Error.Message)"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: Archiving on the remote site during download
Your placement is correct (after all, it's the same what the original code does).
But it's Session.MoveFile, not Session.MoveFiles. And you need to use $transfer.FileName. And Session.MoveFile does not return anything.
$session.MoveFiles($transfer.FileName, $backupPath)
See also
