WinSCP - scripts to open connection and copy files
jobzjoseph
Kuwait
We have a small problem that we need a solution for :-
We are trying to copy files from a non SFTP Windows server to an SFTP server using Winscp.
We need to create a batch that can open the session and keep it active for atleast 8 hours and keep copying files on regular basis or sync them.
In order to do that we thought the best approach would be to create a batch to login to SFTP server and keep the server active and at the same time create another batch to keep copying the files on loop.
Appreciate your support and best recommendations with the above logic. We have created some scripts to open the session and copy the files as below.
Login to session
option batch off
open sftp://testuser01:P@ssw0rd@hostname
Copy the Files
option batch off
open sftp://testuser01:P@ssw0rd@hostname/
cd Swifttest/paymentsafe/PS_TO_SAA
put "D:\paymentsafe_bbyn\localFolder\From_PS_To_SAA\*.out"
put "D:\paymentsafe_bbyn\localFolder\From_PS_To_SAA\*.txt"
# Disconnect
close
Re: WinSCP - scripts to open connection and copy files
You cannot do loop in WinSCP script.
So either you will have to loop outside of the script (which means a reconnect for each iteration).
Or use WinSCP .NET assembly from your favorite scripting language (like PowerShell), where you can do the loop.
https://winscp.net/eng/docs/library_powershell
Or use keepuptodate command:
https://winscp.net/eng/docs/scriptcommand_keepuptodate
