Edit files with long paths
falco20019
Most of Windows still has problems with long file names. Even though WinSCP is able to download and show them in internal editor, it's not possible to use an external editor right now if the path name gets too long.
If I open the file locally, Windows is circumventing this by using
C:\Users\myusername\AppData\Local\Temp\scp32179\plugins\servlet\CONFLU~1\default\Global\LIV3DEV\LIV3DE~1\Products\WAREHO~1\WAREHO~1\TECHNI~1\PACKAG~1.IUM
instead of
C:\Users\myusername\AppData\Local\Temp\scp32179\plugins\servlet\confluence\default\Global\LIV3DEV\LIv3 Development\Products\warehouseNAVIGATION\warehouseNAVIGATION MSP\Technical Specification%3A warehouseNAVIGATION MSP\Package.Sub.TruckCommunication.GetLoadSensorOrder.iuml
WinSCP is trying to open the editor using the full filename instead of the 8.3 formatted version which fails.
I'm using WebDAV with Confluence in this case and have therefore no influence on the length of the filenames and resulting paths.
falco20019
The editor doesn't matter. Tried it with Windows Notepad and Notepad++. It seems that Windows is not capable of using long paths in arguments (or in the Windows API when the program tries to open that file).
I have set
\\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem\LongPathsEnabled
in my registry to 1. But this only leads to the effect, that double clicking the file will use
notepad.exe C:\Users\myusername\AppData\Local\Temp\scp32179\plugins\servlet\CONFLU~1\default\Global\LIV3DEV\LIV3DE~1\Products\WAREHO~1\WAREHO~1\TECHNI~1\PACKAG~1.IUM
as system call instead of the full path.
