SSIS to SFTP using WINSCP
chaitanya.brindavan@gmail.com
Seattle
Hey,
I am trying to export some files on my local folder to an SFTP location using SSIS....I need the command line to accept the hostkey always. Can you please let me know what am i missing here?
/command "open sftp://myusername:mypassword@myportal -hostkey="ssh-rsa 2048 ...........................="" "put D:\xxx\xxx\*.CSV /xxx/xxxx/" "exit"
Re: SSIS to SFTP using WINSCP
You seem to have quotes wrong.
It should be like:
/command "open sftp://myusername:mypassword@myportal -hostkey=""ssh-rsa 2048 ...........................=""" "put D:\xxx\xxx\*.CSV /xxx/xxxx/" "exit"
See https://winscp.net/eng/docs/commandline#syntax
The easiest is to have WinSCP GUI generate a script template for you:
https://winscp.net/eng/docs/ui_generateurl#script
