Add folders to sort custom commands
Messiah93
Messiah93 avatar
Belgium
Hey!
I'm using a lot of custom commands, I find it might be cool to be able to sort them into "folders" that would appear in the top bar of custom commands instead of having a long list popping out of the screen. I have actually 54 customs commandes and I can't use the custom commands top bar because it popping out of the screen. I have to right click in the distant panel for trigger a custom command. It's just a simple feature, it might be cool :)
Thank's :)
