Powershell WebDav protocol error message 405 Method Not Allowed"
I need to make a powershell script to put files with Webdev. I generated the code from the GUI (file transfer worked ok with GUI) and added some code. Get error message: 405 Method Not Allowed"
This is the script:
This is the script:
# Parameters $PRODUCTIE = "Ja" $FILE = "getalladusers.csv" $LOCALPATH = "\\data\Afdeling\filename" $REMOTEPATH = "/webdav/import" Write-Host "PRODUCTIE = $PRODUCTIE " Write-Host "FILE = $FILE " Write-Host "LOCALPATH = $LOCALPATH " Write-host "REMOTEPATH = $REMOTEPATH" Write-Host " " # Load WinSCP .NET assembly Add-Type -Path 'C:\Program Files (x86)\WinSCP\WinSCPnet.dll' # Set up session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Webdav HostName = "ddd.desk.net" PortNumber = 443 UserName = "WebDav" Password = "32pyd-y22cq-v4ddq" WebdavSecure = $True } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Start Your code $transferResult = $session.PutFiles("$LOCALPATH\$FILE", "$REMOTEPATH", $False, $transferOptions) # Throw on any error $transferResult.Check() # Print results foreach ($transfer in $transferResult.Transfers) { Write-Host ("Upload of {0} succeeded" -f $transfer.FileName) } }
