Can't list root directory
wolfgangp
On some servers I can't go the the root/base "/" directory. The directory get never listed and the connection get closed because there is a server timeout. If I specify another directory in the option menu I can connect without problems and can work as usual. But if I go then to the root directory "/" the connection get closed. I also restarted the service on the remote server without success. On another server I have the same problem.
The log contains the process from switching from the home direcotry to the root directory.
My system:
WinSCP 5.17.3 Build 10325
Windows 10
Using GUI
Connection: SFTP with private key authentication
Remote server:
Server: Debian 9.12 / 10.3
wolfgangp
Re: Can't list root directory
Can you browse to that folder in any other SFTP client?
Same problem with Filezilla. Ok, then the problem is related to the server and not winscp. Thx
