WINSCP SFTP authentification in script fails
Patchi
Did anyone encounter issues with authentification in script ?
I have a couple of scripts that are OK, using a full commande line (protocol, user, password, host, port, hostkey).
But this one fails whereas typing each parameters at the commande line is OK.
I read the FAQ, documentations, doublechecked the parameters are correct
Is there a mean to pass arguments (user, password especially) one by one, on seperate lines in a script ?
Script
open sftp://lar_user_test:***@83.206.193.82 -hostkey="ssh-rsa 2048 ....4="
Searching for host...
Connecting to host...
Authenticating...
Using username "lar_user_test".
Access denied.
Access denied.
Connection has been unexpectedly closed. Server sent command exit status 0.
Access denied.
Access denied.
Command line
winscp> open
Host: 83.206.193.82
Authenticating...
Username: lar_user_test
Password:
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [2] 83.206.193.82
winscp> bye
Patchi
Finally,
I used the windows interface and exported (Generate Session URL Code) the sesssion, that created a commande line that is OK.
It is strange to see that the ssh key was chrunked and the password contains "%".
But it works !!
open sftp://lar_user_test:%2xx%xx%2xx@83.206.193.82/ -hostkey=""ssh-rsa 2048 XbaOy07AZUIIkurQCDFH9oAYPp2g0NsmjQ9aSNq+5q4="""
ovakho
CLC
Host key does not match configured key fingerprint
All attempts to connect to the vendor’s server failed with the same message:
open sftp://<username>@<domain>.com -hostkey="key fingerprint from Private key"
Authenticating...
Host key does not match configured key fingerprint "ssh-rsa 2048 key fingerprint from Private key "!
Host key fingerprint is ssh-rsa 2048 N+G9MpbdPHnqznk7xw/LtdK4NJZTzhv8MlZDS0bt8UQ=.
Authentication failed.
The server's ssh-ed25519 key fingerprint is:
ssh-ed25519 255 <fingerprint >
How is it possible that it shows the key type of ssh-ed25519, while the generated key-pair is ssh-rsa 2048?
What am I missing?
