Error changing directory to '/'. Out of memory
muhammedfazee
India
I have a powershell script which transfer a file to SFTP server.
I am getting the following error
while executing
$session.PutFiles(filePath, sftpPath, false, transferOptions)
Note:
$transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
Re: Error changing directory to '/'. Out of memory
