Enumerate local assets matching $transferoptions.filemask
Ch33s3
World
Hi again,
I'd like to count all local assets matching my filemask, regardless of its state (already synced or not should not matter in this case)... is there a way to archive this with WinSCP ?
heres my approach, would you be so kind an help me out again on this one ?
# Connect
######FILEMASK-SETTING#######
$transferoptions = New-Object WinSCP.TransferOptions
$transferoptions.filemask=$acceptedExtensions
$LocalAcceptedAssets = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $True ,$True, [WinSCP.SynchronizationCriteria]::Size, $transferOptions)
$LocalAssetCount = 0
$LocalAssetCountSize = 0
foreach ($asset in $LocalAcceptedAssets)
    if (($asset.Action -eq [WinSCP.SynchronizationAction]::null) -or
        ($asset.Action -ne [WinSCP.SynchronizationAction]::null))
        $LocalAssetCount++
        $LocalAssetCountSize += $asset.Local.Length
Write-Host "$LocalAssetCount Assets ($LocalAssetSizeCountGBConvertedR GB) in total"
# Disconnect, clean up
$session.Dispose()
Have a nice day and thanks for your help !
Ch33s3
World
as a small addition to whoever might find a need for this, this is my current workaround;
try
    $folderInfoSpec1 = Get-ChildItem -Path $localfolder -Filter *.mxf | Measure-Object -Property Length -Sum
    $folderCountSpec1 = $folderInfoSpec1.Count
    $folderSizeSpec1 = $folderInfoSpec1.Sum
    $folderInfoSpec2 = Get-ChildItem -Path $localfolder -Filter *.xml | Measure-Object -Property Length -Sum
    $folderCountSpec2 = $folderInfoSpec2.Count
    $folderSizeSpec2 = $folderInfoSpec2.Sum
    $folderInfoSpec3 = Get-ChildItem -Path $localfolder -Filter *.jpg | Measure-Object -Property Length -Sum
    $folderCountSpec3 = $folderInfoSpec3.Count
    $folderSizeSpec3 = $folderInfoSpec3.Sum
finally
    $folderInfoSpec1Converted = $folderSizeSpec1 /= 1073741824
    $folderInfoSpec1ConvertedR = [Math]::Round($folderInfoSpec1Converted,2)
    #Write-Host "$folderCountSpec1 MXF Assets ($folderInfoSpec1ConvertedR GB) in total"
    $folderInfoSpec2Converted = $folderSizeSpec2 /= 1073741824
    $folderInfoSpec2ConvertedR = [Math]::Round($folderInfoSpec2Converted,2)
    #Write-Host "$folderCountSpec2 XML Assets ($folderInfoSpec2ConvertedR GB) in total"
    $folderInfoSpec3Converted = $folderSizeSpec3 /= 1073741824
    $folderInfoSpec3ConvertedR = [Math]::Round($folderInfoSpec3Converted,2)
    #Write-Host "$folderCountSpec3 JPG Assets ($folderInfoSpec3ConvertedR GB) in total"
    ### Combine all values
    $folderCountSpecCombined = $folderCountSpec1 + $folderCountSpec2 + $folderCountSpec3
    $folderInfoSpecCombined = $folderInfoSpec1ConvertedR + $folderInfoSpec2ConvertedR + $folderInfoSpec3ConvertedR
    Write-Host "$folderCountSpecCombined Assets with accepted filetypes ($folderInfoSpecCombined GB) in total"
    $session.Dispose()
