SFTP Intermittent connection
jun.malapira
Philippines
we created a batch file and set it on task scheduler. we are having intermittent connection with error"Handling network read event on socket 1000 with error 0" before it disconnect. when we run the batch file manually it will run with no issue. intermittent means sometimes work and sometimes wont. any suggestion that can help us please?
Re: SFTP Intermittent connection
Please attach a full session log file of both successful and failed session (using the latest version of WinSCP).
