Running WinSCP when using Remote Desktop (RDP)?
ddwashbu
Cedar Rapids, Iowa USA
I discovered WinSCP only recently but I absolutely love it! I'm running the latest version, 5.17.3.
I'm one of the many people now working from home and unfortunately WinSCP doesn't seem to work when I remote into my desktop at work and try to run it there. I can see the process running in task manager, but the GUI never appears.
I was able to run into work this morning and it works fine locally. I left it running, but now when I'm at home using RDP, Windows says "not responding".
Any ideas?
Thanks and Best Regards,
Don Washburn
Re: Running WinSCP when using Remote Desktop (RDP)?
ddwashbu
I followed the directions for the debug version but the WinSCP GUI never appears. I can it the process in Task Manager, but that's all. See attachments.
  • 2020-04-24_12-45-25.png (40 KB, Private file)
Description: Taskbar
  • 2020-04-24_12-45-09.png (15.65 KB, Private file)
Description: Task Manager
r_ant_1
Canada
Similar bug in that after leaving running with RDP and closing, it no longer open folders
After leaving a RDP and re-opening, existing WinSCP sessions do not allow entering into folders on the local side on mapped drive. Remote side is fine.
Re: Similar bug in that after leaving running with RDP and closing, it no longer open folders
@r_ant_1: Thanks for your report.
