Enable PTY ?
ohyes
Enable PTY ?
I must connect to a server via putty using -t option ('enable PTY').
Connecting to this server does not work, I guess because I did not pass -t option.
How can I pass this option to WinSCP?
Thanks!
ohyes
"Why do you need PTY to connect?"
I tried to connect to the server with putty and without '-t', but it does not work. The option -t is mandatory for this server.
No chance to add this option in WinSCP ? Or do you know an alternative ?
Thanks.
Once again, PTY is mutually exclusive to SFTP/SCP protocols. In other words, no SFTP nor SCP client can ever work with a server that does not allow connections without a terminal emulation. It has nothing to do with WinSCP.
If you want us to help you further, please provide more details than "it does not work".
ohyes
Here is the error I get when I ommit -t:
$ ssh user@@ssh.server.com /bin/bash
password: xxx
FS Error: ssh must be used with the -t option to enable PTY
