(Exception) **Host key does not match configured key fingerprint "ssh-rsa 1024 KfH2Zul0c+lnIQ3vIRz7s
syedshareefahmed@gmail.com
I have a script (Batch file) for transferring files to a remote server with private keys provided by the party who owns the remote server. Sometimes I am receiving an error as below and files not been send.
(Exception) **Host key does not match configured key fingerprint "ssh-rsa 1024 KfH2Zul0c+lnIQ3vIRz7slq71crPirz+3ZkvwA5gulE="!**
My batch file is given below.
@echo off
  /log="C:\writable\path\to\log\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://user:password@remoteserver:10039/ -hostkey=""ssh-rsa 1024 KfH2Zul0c+lnIQ3vIRz7slq71crPirz+3ZkvwA5gulE="" -privatekey=""E:\FTPPIL\lmsprdedi01.openssh"" -rawsettings AgentFwd=1 KEX=""rsa,ecdh,dh-gex-sha1,dh-group14-sha1,WARN,dh-group1-sha1""" ^
    "cd Outbox/eqmvmt" ^
    "lcd C:\LINES\ProdFTPEDIOUT\PIL\Coarri" ^
    "put *.* -nopreservetime" ^
    "lcd C:\LINES\ProdFTPEDIOUT\PIL\Codeco" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Kindly help me to resolve this issue, looking forward to your earliest support and co-operation.
Re: (Exception) **Host key does not match configured key fingerprint "ssh-rsa 1024 KfH2Zul0c+lnIQ3vIRz7s
Where did you get the ssh-rsa 1024 KfH2Zul0c+lnIQ3vIRz7slq71crPirz+3ZkvwA5gulE= from?
A fingerprint of the host key of the server you are connecting to is ssh-rsa 1024 2aQE3Q82arBxCXSCUeGF3HqfeYMh25YX9bVc5g1Qmhc=.
Either you have done something wrong or the hostkey has changed or you are under MITM attack.
syedshareefahmed@...
Thanks a lot Mr. Martin for responding.
I have got this fingerprint from the script WinSCP 'Generate Session URL/Code' of Manage option after login with credentials provided by the receiver of the files by remotely. And the host key also has provided by them.
A screenshot for reference also attached.
Description: The fingerprint of the host key got from Manage-> Generate Session URL/Code after login to WinSCP. And the host key provided by one of our stakeholders to receive files remotely.
What if you first log in, then go to Session > Generate Session URL/Code?
Dear Martin,
Yes, your are correct, the host key was generated when I do log then, goto Session > Generate Session URL/Code.
I'm not sure I understand. So is it working now?
