Winscp.net Append on FTP using ExecuteCommand in PowerShell
Protuberus
Canada
The OverwriteMode Append is not supported for a FTP connection in WinScp.net and the server that I communicate with doesn't allow a SFTP connection.
Can send a append command using the execute command?
I tried some variations of the following with no luck so far:
$session.ExecuteCommand("append file1").Check()
I get the following error returned by the server:
500 'APPEND file1': command not understood.
Thank you,
