curve25519-sha256 kex not supported in WinSCP
Guest25519
WinSCP Version 5.17.5 on Windows 7 x64. It has not worked on any previous version of WinSCP either.
Using SFTP. Using GUI.
The remote server is configured with:
KexAlgorithms curve25519-sha256
Please note that curve25519-sha256 is the newer name for the deprecated curve25519-sha256@libssh.org
I get the following error when trying to connect:
Error
Couldn't agree a key exchange algorithm (available: curve25519-sha256)
OK Reconnect Help
Log attached.
  • winscp.log (3.72 KB, Private file)
Re: curve25519-sha256 kex not supported in WinSCP
This request has been added to the tracker:
https://winscp.net/tracker/1865
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
