Exclude files starting with a specific name
natchiram
Hello guys,
I am trying a script to download all the files generated today but exclude the files that start with "temp". I am able to get all the files today using the filemask
get -filemask=*>=today but I am not sure how to add exclude file mask to leave the files that start with "temp"
I tried get -filemask=*>=today | temp* and some other variations but not getting any success. I am missing something but not sure what. Any suggestions?
Regards,
Ram
natchiram
Re: Exclude files starting with a specific name
No spaces (or wrap the mask to quotes):
get -filemask=*>=today|temp*
Thanks for your reply. Without wrapping the filemask, the script wouldn't even run but with wrapping, I am getting this error "Missing parameter for command 'get'"
natchiram
WinSCP version that I am using is 5.17.5 Build 10414
This is the code that I am using
@echo off
  /log="C:\Users\username\Documents\WinSCP\WinSCP.log" /ini=nul ^
  /command ^
    "open ftp://server details/ -rawsettings ProxyPort=0" ^
    "cd /folder" ^
    "lcd \\path" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
natchiram
You didn't mention batch file until now.
It should be like this then:
     "get -filemask=*>=today|temp*" ^
Or:
     "get -filemask=""*>=today | temp*""" ^
See:
https://winscp.net/eng/docs/faq_batch_file#quotes
https://winscp.net/eng/docs/faq_batch_file#newline_escaping
Sorry, I should have mentioned that. Thanks for your suggestions and tried both the variations with same result but your second link on "New-line Escaping" has "get *" ^ in the example. So I tried "get -filemask=*>=today|temp* *" ^ and it finally worked. Thanks for pointing me in the right direction.
