How can I change the time zone being used in XML Loggin Session Element - Start Attribute?
Msledge
<session xmlns="http://winscp.net/schema/session/1.0" name="example@ftp.example.com" start="2020-05-03T02:50:20.348Z">
Can anyone show me how to change the time zone used when the XML logging file is generated? I am in Central Time Zone - I believe the time zone listed in the example is UTC.
Thank you!
Michael
Re: How can I change the time zone being used in XML Loggin Session Element - Start Attribute?
The XML logging always uses UTC time (that's the the Z means).
Stevaz
Genova
so, if I need logging i must use SessionLog?
It's impossible change time zone in CET or CEST?
Session Log is to verbose to use for have a log
Yes, it's in UTC (that's what the trailing Z means). It cannot be changed.
