console synchronize with multiple files at once
How can I upload or download several files at the same time when I sync?
I'm looking in the documentation but can't find it. Is there a parameter to add?
winscp.com /ini=nul /command ^
    "open ftp://lalala/" ^
    "option batch continue" ^
    "mkdir /PROB/2020-05-06/" ^
    "option batch abort" ^
    "synchronize remote -delete E:\PROB\2020-05-06\ /PROB/2020-05-06/" ^
    "exit"
Re: console synchronize with multiple files at once
Do you mean in parallel? No, parallel transfers are not supported in scripting. And actually not even in GUI, when synchronizing.
