Connect without browse directory
jlindgren
I have an FTP site I'm needing to send files to that will not allow the FTP client to browse the directory upon connection. WINSCP seems to inherently want to browse the directory even if using command lines. I need to connect with batch and txt files, open the connection with user and password and then do a simple PUT command. Is there a way to shut off the directory browsing so I can accomplish this?
Thanks.
Re: Connect without browse directory
