Connecting to S3 bucket and transferring files via Batch script
I am able to connect to the S3 bucket using the GUI. When I try to connect using a Windows batch script, I get "Access Denied" error message.
I have attached the Log file for your reference. The batch script is as follows:
Venkitachalam Subramanian
:: This script takes care of sending the daily dispute file to Feedzai. echo on echo %date% %time% set JOB=$RB0140F set cc=%date:~0,3% set dd=%date:~7,2% set mm=%date:~4,2% set yy=%date:~10,4% set hh=%time:~0,2% set mi=%time:~3,2% set ss=%time:~6,2% "C:\Program Files (x86)\WinSCP\WinSCP.exe" ^ /log="C:\EDUSER\PROJECTS\CASSMSTR\OUTBOUND\FEEDZAI\LOGS\WinSCP_%dd%.log" /ini=nul ^ /command ^ "open s3://AWS Access Key:AWS Secret Key@s3.amazonaws.com/feedzai-qa-chv-batch-processor-qa-us-east-1/input/ -rawsettings PingType=1" ^ "lcd C:\EDUSER\PROJECTS\CASSMSTR" ^ "cd /feedzai-qa-chv-batch-processor-qa-us-east-1/input" ^ "put Hello.txt" ^ "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) exit /b %WINSCP_RESULT%
