Cant rename files
taylorabc101
Cant rename files
This is more of an SFTP issue but I've run out of places to ask for help.
I currently have a atmoz/sftp docker container setup with one user. I can create/move/delete files but when I try to rename a file I get error code 3 permission denied. This is using winscp and the folder permission mask is 777. so the file I create has permissions 777 when I try to rename it and is owned by user.
File structure: /home root:744 /user root:744 /home user:777 /subdirectory user:777 ...files user:777
Home is owned by the user with 777 perms for testing purposes
sshd_config:
# Secure defaults
# See: https://stribika.github.io/2015/01/04/secure-secure-shell.html
Protocol 2
HostKey /etc/ssh/ssh_host_ed25519_key
HostKey /etc/ssh/ssh_host_rsa_key
# Faster connection
# See: https://github.com/atmoz/sftp/issues/11
UseDNS no
# Limited access
PermitRootLogin no
X11Forwarding no
AllowTcpForwarding no
# Force sftp and chroot jail
Subsystem sftp internal-sftp
ForceCommand internal-sftp
ChrootDirectory %h
# Enable this for more logs
#LogLevel VERBOSE
I cannot figure out what is stopping me from renaming files
Steps to reproduce: -Copy docker-compose.yml -Edit to function in your environment -docker-compose up
docker-compose.yml
version: '3'
services:
sftp:
image: atmoz/sftp
ports:
- "4570:22"
volumes:
- "./DIRECTORY_TO_COPY:/home/${NAME}/home/Storage"
command: ${NAME}:${PASSWORD}:1001
