WinSCP.SessionLocalException: 'Fingerprint for algorithm MD5 not supported'
moctey
I am receiving this error now:
Looks like it came after a change of fingerprint or more on the server.
What can I do? my algorithm parameter is "MD5"
Re: WinSCP.SessionLocalException: 'Fingerprint for algorithm MD5 not supported'
What server is that? SFTP or FTPS? Or other? Please attach a full session log file showing the problem (using the latest version of WinSCP).
moctey
Log
I am using the .NET API
Here is the relevant part of the log:
. 2020-05-29 12:28:35.246 Connecting to ftp.xxxx.com:6200 ...
. 2020-05-29 12:28:35.266 Connected with ftp.xxxx.com:6200, negotiating TLS connection...
< 2020-05-29 12:28:35.281 220 xxxFTP Server
> 2020-05-29 12:28:35.281 AUTH TLS
< 2020-05-29 12:28:35.299 234 Using authentication type TLS
. 2020-05-29 12:28:35.458 Verifying certificate for "xxxx" with fingerprint xxxx and 18 failures
. 2020-05-29 12:28:35.458 Certificate common name "ftp.xxxxx.com" matches hostname
. 2020-05-29 12:28:35.459 Using TLSv1.2, cipher TLSv1.2: AES256-GCM-SHA384, 4096 bit RSA, AES256-GCM-SHA384       TLSv1.2 Kx=RSA      Au=RSA  Enc=AESGCM(256) Mac=AEAD
. 2020-05-29 12:28:35.459 TLS connection established. Waiting for welcome message...
< 2020-05-29 12:28:35.490 230 Logged on
> 2020-05-29 12:28:35.490 SYST
< 2020-05-29 12:28:35.505 215 UNIX emulated by FileZilla
> 2020-05-29 12:28:35.505 FEAT
< 2020-05-29 12:28:35.521 211-Features:
< 2020-05-29 12:28:35.521  MDTM
< 2020-05-29 12:28:35.521  REST STREAM
< 2020-05-29 12:28:35.521  SIZE
< 2020-05-29 12:28:35.521  MLST type*;size*;modify*;
< 2020-05-29 12:28:35.521  MLSD
< 2020-05-29 12:28:35.521  AUTH SSL
< 2020-05-29 12:28:35.521  AUTH TLS
< 2020-05-29 12:28:35.521  PROT
< 2020-05-29 12:28:35.521  PBSZ
< 2020-05-29 12:28:35.521  UTF8
< 2020-05-29 12:28:35.521  CLNT
< 2020-05-29 12:28:35.521  MFMT
< 2020-05-29 12:28:35.521  EPSV
< 2020-05-29 12:28:35.521  EPRT
< 2020-05-29 12:28:35.521 211 End
> 2020-05-29 12:28:35.522 CLNT WinSCP-release-5.17.5
< 2020-05-29 12:28:35.537 200 Don't care
> 2020-05-29 12:28:35.537 OPTS UTF8 ON
< 2020-05-29 12:28:35.554 202 UTF8 mode is always enabled. No need to send this command.
> 2020-05-29 12:28:35.554 PBSZ 0
< 2020-05-29 12:28:35.570 200 PBSZ=0
> 2020-05-29 12:28:35.570 PROT P
< 2020-05-29 12:28:35.585 200 Protection level set to P
. 2020-05-29 12:28:35.586 Connected
. 2020-05-29 12:28:35.586 --------------------------------------------------------------------------
. 2020-05-29 12:28:35.586 Using FTP protocol.
. 2020-05-29 12:28:35.586 Doing startup conversation with host.
> 2020-05-29 12:28:35.586 PWD
< 2020-05-29 12:28:35.603 257 "/" is current directory.
. 2020-05-29 12:28:35.603 Getting current directory name.
. 2020-05-29 12:28:35.603 Startup conversation with host finished.
Re: Log
FileZilla server does not support any checksum calculation command by default.
You can enable HASH command by editing FileZilla Server.xml:
<Item name="Enable HASH" type="numeric">1</Item>
not sure what is the link with scanFingerprint?
Anyway I found out that I needed to use "SHA-1" instead of "MD5". Probably linked to a change of certificate on the thirdparty server
