batch script and wildcard (problem with *)
serfisar
Hi!
Please, explain me this issue.
When I'm using this command from cmd (manually)
get *%x%.csv
where x = 2020_02_03
Everything working fine
But, when I use it in batch script, WinSCP copy all files from directory.
Re: batch script and wildcard (problem with *)
It must be something about your batch file. As such, it's probably not a WinSCP problem, but if you post your batch file, we can take a look anyway.
serfisar
set WinSCP="C:\winscp\winscp.exe"
cd C:\lftp-4.6.5.win64-openssl\bin
date.exe "+%Y-%m-%d" --date="1 day ago" > C:\Temp\tmp
set /p x= < C:\Temp\tmp
del C:\Temp\tmp
set protocol=ftp
set user=MY_USER
set password="MY_PASSWORD"
set host=SOMEHOST
%WinSCP%  %protocol%://%user%:%password%@%host% /command "lcd C:\recon\input" "get *%x%.csv" "exit"
I do not see any problem. Please attach a full session log file showing the problem (using the latest version of WinSCP).
Did you check the output of the batch file? How does the final WinSCP command-line look like?
Though are you aware, that you can implement this easily with WinSCP TIMESTAMP feature?
https://winscp.net/eng/docs/scripting#timestamp
... "get *%%TIMESTAMP-1D#yyyy-mm-dd%%.csv" ...
