Release 5.17.6 doesn't show column type for remote!
skunki07
after installng Release 5.17.6 I realize that I cannot activate column "type" for the remote server. I can select the column but it doesn`t appear in the list!
Regards
Wolfgang Kunk
Re: Release 5.17.6 doesn't show column type for remote!
I do not think it's related to WinSCP upgrade. What do you mean by "can select the column"? Do you mean that you have ticked the column in the menu of columns to show?
Anyway, I suggest you reset your panel configuration by removing the following registry key:
HKCU\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\RemotePanel
skunki07
Thank you very much, that was the trick.
The Type column is back! :-)
Regards
Wolfgang Kunk
