Hi, how does one 'remove BMO' using the .Net Assembly?
Re: Hi, how does one 'remove BMO' using the .Net Assembly?
gbmarshall99 wrote:
I'm getting a BMO mark (3 letters) in the front of the files I upload using WINSCP .Net Assembly.
It sounds like you believe WinSCP is adding those. It is not. The BOM must be in your original files already.
How does one enable Remove BMO in .Net Assembly?
https://winscp.net/eng/docs/ui_transfer_custom
Use RemoveBOM raw transfer setting:
https://winscp.net/eng/docs/rawtransfersettings#removebom
gbmarshall99
This code didn't work:
sessionOptions.AddRawSettings("RemoveBOM", "1")
Any suggestions?
