Protecting credentials used for automation
BR365
I've already read the information about the Protecting of credentials. But I still don't know exactly how to put all this together.
At the moment, I have a batch file and a config file. The Batch is defining some standard path informations and the config file manages the SFTP transfer.
I also understand how to encrypt the password and created an XML file as shown in the example with the encrypted password.
But how can I now use this part:
# Read XML configuration file
[xml]$config = Get-Content ".\config.xml"
# Use read credentials
    HostName = "example.com"
    UserName = $config.Configuration.UserName
    Password = $config.Configuration.Password
and
Read-Host -AsSecureString | ConvertFrom-SecureString
and
$sessionOptions.SecurePassword = ConvertTo-SecureString $config.Configuration.Password
Can someone provide me a complete example, not only these fragments?
Moritz
Re: Protecting credentials used for automation
I have updated the article for more clarity.
For a more specific example of use of the Read-Host ..., see also the C# section of the article.
asad
uk
@martin Are you sure this works because I get the error below:
Exception calling "Open" with "1" argument(s): "SessionOptions.Password is set, but SessionOptions.UserName is not."
At C:\Temp\KKremoteConfig.ps1:17 char:1
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : ArgumentException
Also, is it possible to encrypt the hostname and SSH fingerprint?
Hi Martin,
Apologies, I’m following this article:
I’m using PowerShell and the ConvertFrom-SecureString method to encrypt the password in the XML file.
Here’s the contents of my configuration file:
<Configuration>
<UserName>myuser</UserName>
<Password>encrypted-password</Password>
</Configuration>
Here are the contents of my PowerShell script:
# Import the WinSCP assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll" # Modify the path as per your WinSCP installation location
$config = Get-Content "C:\Temp\config.xml"
# Configure WinSCP session options
   HostName = "sftp.myserver.com"
   SshHostKeyFingerprint = "MySSHHostKeyFingerprint"
# Initialize a WinSCP session
# Open the WinSCP session with the specified session options
When running this I get the following output:
ConvertTo-SecureString : Cannot bind argument to parameter 'String' because it is null.
At C:\sftp.ps1:12 char:45
+ ... ecurePassword = ConvertTo-SecureString $config.Configuration.Password
+ CategoryInfo : InvalidData: (:) [ConvertTo-SecureString], ParameterBindingValidationException
+ FullyQualifiedErrorId : ParameterArgumentValidationErrorNullNotAllowed,Microsoft.PowerShell.Commands.ConvertToSecureStringCommand
At C:\sftp.ps1:21 char:1
The password isn’t being picked up from the config.xml file
The UserName isn’t being picked up from the config.xml file
When I use the plain text password method I get the following:
In this instance just the following issue:
So to sumarise, I require some assistance to understand why:
The UserName isn’t being set
The SecurePassword method isn’t working.
Additionally, just a minor query, is it possible to store other parameters such as HostName and SshHostkeyFingerprint in the config.xml file?
You have removed the [xml] declaration from this line:
That's what breaks the script.
And yes, you can of course set any property using this method. Those are just plain string values, there's no magic.
