Conpying/Transfrring file Error - invalid session token
vidisha
pune
Hi Guys,
I am getting an error as "Invalid Session token ...authentication failure" while doing oprations like copy paste file, create new file, update existing file etc...
I am using SCP protocal.
Did anyone faced the same issue.
Please help. I am in lot of trouble because of the issue
Re: Conpying/Transfrring file Error - invalid session token
