New Server 2016 cannot read remote directory
To All,
I am setting up a new Server2016 within a domain and have installed IIS FTP, added a user for the purpose of FTP, made sure that the FTP user has rights to the ftp root which is c:\inetpub\wwwroot. The log below shows how I can create a secure connection but fail to read the remote directory. I am a programmer much more than a server expert and use the FTP to publish my websites to the server from my development platform. I set this up fine on my Server2012 machine years ago without encryption but very much wish to use encryption for the new 2016 Server. Any help appreciated!
Greg
. 2020-06-10 19:36:13.263 Using TLSv1.2, cipher TLSv1/SSLv3: FCDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA, FCDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=ASGCM(256) Mac=AEAD
. 2020-06-10 19:36:13.272 TLS connection established. Waiting for welcome message...
> 2020-06-10 19:36:13.272 USER myusernameishere
< 2020-06-10 19:36:13.272 331 Password required
> 2020-06-10 19:36:13.272 PASS *********
< 2020-06-10 19:36:13.301 230 User logged in.
> 2020-06-10 19:36:13.301 SYST
. 2020-06-10 19:36:13.302 The server is probably running Windows, assuming that directory listing timestamps are affected by DST.
< 2020-06-10 19:36:13.302 215 Windows_NT
> 2020-06-10 19:36:13.302 FEAT
< 2020-06-10 19:36:13.303 211-Extended features supported:
< 2020-06-10 19:36:13.303 LANG EN*
< 2020-06-10 19:36:13.313 UTF8
< 2020-06-10 19:36:13.313 AUTH TLS;TLS-C;SSL;TLS-P;
< 2020-06-10 19:36:13.313 PBSZ
< 2020-06-10 19:36:13.313 PROT C;P;
< 2020-06-10 19:36:13.313 CCC
< 2020-06-10 19:36:13.313 HOST
< 2020-06-10 19:36:13.313 SIZE
< 2020-06-10 19:36:13.313 MDTM
< 2020-06-10 19:36:13.313 REST STREAM
< 2020-06-10 19:36:13.313 211 END
> 2020-06-10 19:36:13.313 OPTS UTF8 ON
< 2020-06-10 19:36:13.313 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2020-06-10 19:36:13.313 PBSZ 0
< 2020-06-10 19:36:13.313 200 PBSZ command successful.
> 2020-06-10 19:36:13.313 PROT P
< 2020-06-10 19:36:13.313 200 PROT command successful.
. 2020-06-10 19:36:13.336 Connected
. 2020-06-10 19:36:13.337 --------------------------------------------------------------------------
. 2020-06-10 19:36:13.337 Using FTP protocol.
. 2020-06-10 19:36:13.337 Doing startup conversation with host.
> 2020-06-10 19:36:13.351 PWD
< 2020-06-10 19:36:13.352 257 "/" is current directory.
. 2020-06-10 19:36:13.352 Getting current directory name.
. 2020-06-10 19:36:13.386 Retrieving directory listing...
> 2020-06-10 19:36:13.386 TYPE A
< 2020-06-10 19:36:13.387 200 Type set to A.
> 2020-06-10 19:36:13.387 PASV
< 2020-06-10 19:36:13.388 227 Entering Passive Mode (14,111,0,91,209,196).
> 2020-06-10 19:36:13.388 LIST -a
. 2020-06-10 19:36:13.388 Connecting to 14.111.0.91:53700 ...
< 2020-06-10 19:36:13.391 150 Opening ASCII mode data connection.
. 2020-06-10 19:36:28.992 Timeout detected. (data connection)
. 2020-06-10 19:36:28.992 Could not retrieve directory listing
Greg
