EVE issue
EngMohammed
EVE issue
Please advise once I try to upload some ILO files in EVE by using WinSCP below error message displays to me:
root@eve-ng:~# /opt/unetlab/wrappers/unl_wrapper -a fixpermissions
PHP Warning:  file_get_contents(/opt/unetlab/platform): failed to open stream: No such file or directory in /opt/unetlab/html/includes/init.php on line 71
Re: EVE ISSUE
Sorry, I do not understand how is your question related to WinSCP.
James S
Re: EVE ISSUE
Hi did you get this resolved? I'm currently having the same issue after uploading images to eve-ng via WinSCP. I am receiving the same error when I apply
Williann
EVE-NG ISSUE
Resolvieron el problema tengo el mismo problema
visakh
Re: EVE ISSUE
edit line 71 of file init.php
vi /opt/unetlab/html/includes/init.php
remove "platform" from line 71
$kvm_family = file_get_contents("/opt/unetlab/");
save file and execute
Titu
eve-ng fixed permission issue
Thanks visakh.. Issue resolved.
jppune35
php71 line issue resolved but palo image not starting active.
Sahil Kalra
PHP Notice: file_get_contents(): read of 8192 bytes failed with errno=21 Is a directory in /opt/une
After running permissions command getting below error.
PHP Notice: file_get_contents(): read of 8192 bytes failed with errno=21 Is a directory in /opt/unetlab/html/includes/init.php on line 71
abadar23
Has anyone fixed the issue?
Can't execute
Trying to load Linux image pack for EVE. Has the same warning
Does anyone know how can this be fixed?
Re: EVE issue
I'm locking this thread, as none of this is about WinSCP.
This topic is locked: you cannot edit posts or make replies
