Sorting files by type (files containing only the extension in the name)
kanlukasz
Good morning
I have a suggestion to change the sort method for sorting by type
At the moment it looks like this:
From a logical point of view, this is obviously the right way, but if we think about it deeply, I see some confusion here (about files with .dot only)
OK, let's look at Total Commander now:
Files with the .dot extension are first
It makes work much easier
Visual Studio Code, PHPStorm, they also use this method:
What do you think?
Re: Sorting files by type (files containing only the extension in the name)
Thanks for your suggestion.
We will see, if more people ask for this.
