AWS S3 listing files and folders issue
ptessels1985
Netherlands
Hello Everyone,
I am having some issues with the AWS S3 listing files and folders.
When I connect with bucketname.s3.amazonaws.com I am logged in and see nothing but when I connect with s3.amazonaws.com I see all buckets and if I add a remote folder in the advanced settings I end up in the right folder but the bucketname.s3.amazonaws.com should also work.
Does anyone have any idea what is going on? Have I forgotten to add something?
Hope anyone can shed some light on this.
Re: AWS S3 listing files and folders issue
When connecting to AWS S3, use s3.amazonaws.com hostname. Do not change it.
What are you trying to achieve?
