Transfer file from server to server
relindwto6
USA
I tried many times. It just not working. When I use put command, it will list the files needed to transfer, then just hang there.
I am basically wanting to transfer files from first server to second server in remote location
When I close the hanged dos
I tried before, transfer from my local xp to remote server, no problem at all. But when I put the script into remote server, in order to server1 transfer to server2, it hang at put command.
Re: Transfer file from server to server
