Make Encryption Algorithm's ssh2_id Property Accessible in .NET Assembly
TheCliGuy
When a session is opened to an SSH/SFTP server, the WinSCP log includes details of the encryption algorithm that's used.
The PuTTY code responsible for recording the encryption algorithm uses a human readable description. This description has no significance outside of PuTTY, consequently this makes it impossible to cross-reference it against the IANA's Secure Shell Encryption Algorithm Name registry (https://www.iana.org/assignments/ssh-parameters#ssh-parameters-17).
Here's the code that's responsible for writing to the log:
https://git.tartarus.org/?p=simon/putty.git;a=blob;f=ssh2bpp.c;hb=2762a2025f094bf8ccb75c0bdd7c655bc953f2f1#l132
 132         bpp_logevent("Initialised %s outbound encryption",
 133                      ssh_cipher_alg(s->out.cipher)->text_name);
 134     } else {
 190         bpp_logevent("Initialised %s inbound encryption",
 191                      ssh_cipher_alg(s->in.cipher)->text_name);
 192     } else {
The description is held in the text_name property of an initialised ssh_cipheralg struct. The initialised ssh_cipheralg also contains the encryption algorithm's official IANA name
in the ssh2_id property.
Would it be possible to expose the ssh2_id so it's accessible in the WinSCP .NET assembly (WinSCPnet.dll)?
TheCliGuy
Re: Make Encryption Algorithm's ssh2_id Property Accessible in .NET Assembly
Hello Martin,
Thank you for providing the development version with my suggestion implemented and for doing it so quickly.
I did reply to your email to let you know that I had tested it and it worked perfectly – but I'm not sure if you saw this.
I made one more suggestion which was to also make the ssh2_id value visible from the UI under 'Session' > 'Server/Protocol Information'.
Thanks for your feedback.
I'll make the GUI change, if more people ask for this. Thanks for your understanding.
