WinSCP times out at reading remote Directory
leo-lueder@gmail.com
Germany
Hello Community,
I need to connect via WinSCP from my Windows Computer at home to a Computer at a University. I am using the Uni VPN to connect to the local network. WinSCP worked fine until suddenly it started to always timeout while reading the remote directory. The authentification works so i think that up to that point the connection works fine. Help would be really appreciated.
I used to use a SFTP connection.
Best Regards
Re: WinSCP times out at reading remote Directory
Can you connect and retrieve the directory contents using any other SFTP client?
Germany
i have the same problem when using another client. I can get a working connection with Putty tough.
An exception for WinSCP in my Firewall settings is granted.
Thanky you and best regards
