Works with Windows OpenSSH agent?
rf
Hi, I'm new to WinSCP, from Filezilla.
Just wondering if it's possible to use WinSCP with Windows OpenSSH agent instead of using Pageant? I have it working with Git nicely so I don't need to enter a passphrase, is this possible with WinSCP?
I've done a bit of searching around but not had much luck so far.
rf
Thanks for the link. I have added it to the tracker.
No problem.
Can you expand on the "use with caution"?
I did have some reservations about installing it initially as I didn't really know what it was doing behind the scenes.
PuTTY Pageant has built-in security features aimed at preventing the keys to be stolen by malicious software. I do not know if winssh-pageant matches that (even if I assume that it is trustworthy software on its own).
