please add failuer and success queues at bottom like filezilla
i can't find witch file traninfer failure with large folder when error hanpened
Re: please add failuer and success queues at bottom like filezilla
The error message will tell you what file failed to transfer, won't it?
if there are more than 10 files failed in a transfer 1000 files task ,how to identified the transinfer-failue files,i think it's terrible
In daily work, I often need to use the FTP upload a project folder to the server, and there are many subfolders, this folder also contains many files, because the project USES a third-party library, usually contains more than 1000 files, if there is a few file transfer among transmission errors, manual processing can also accept, if more has wrong , I can only upload all heavy.
It would be great if I can get:how much failure, how much success, which files failed to upload and I could upload the failed transmissions again in batches At the end of the transfer.
