Can't load .ppk file
I am developing a HowTo for using public key authentication for connections to an sftp server. I edit the Site Profile, Click Advanced, go to SSH-->Authentication, Select Tools, and generate keys (RSA). I put in a passphrase, save the public key file (which will be needed to give to the sftp site) in the "\Program Files (x86)\WinSCP" folder. I then save the private key file to the same folder. Since there's no 'Done' or 'Close' button I just 'X' the generate dialog.
Back in the Site Profile Advanced settings, I then click the '...' button to be able to select the file I just created - not found! When I look in File xplorer in that folder, neither the public nor private key files are there. But, if I open the Generate dialog again and Click "Load" (and existing key file), the file shows up. FYI the filename does NOT contain a space (I saw a forum post about that).
What am I doing wrong? Version 5.17.7 (and, it occurs to me now, I have updated today to that version but NOT rebooted. I'll see if I can squeeze that in).
Paul Trivino
Paul Trivino
