Incompatible with freesshd
WinSCP 5.17.7 on Windows 10, connecting to a freesshd ( http://www.freesshd.com/ ) server on Windows 7 over SFTP using key based auth. I can connect fine, but the folder appears empty. The current path shows up as /, which is wrong. You can't change directories manually, because WinSCP prepends all paths with /.
In the list of options for server shell in the connection properties, there's no way to specify cmd.exe, which would be the right one in this case.
