Delete remote Files if these local no more exists
Toormser
Hello Community,
Is there a way in vbnet Assembly to delete remote files if there are no more available on local storage. My intenation about this is:
1. File Upload (only newer files reg. the FileMask)
2. Check if remote-files are there which are not there on local storage (old files)
3. Delete remote-files, which are not available on local storage
Is there a way for point 2 & 3? You can see my code below.
Public Function UploadBackupToOnlineStorage() As Boolean
    Try
        ' Setup session options
        Dim objSessionOptions As New SessionOptions
        With objSessionOptions
            .Protocol = Protocol.Sftp
            .HostName = "example.com"
            .UserName = "user"
            .Password = "mypassword"
        End With
        Using objSession As New Session
            ' Connect
            objSession.Open(objSessionOptions)
            ' Upload files
            Dim objTransferOptions As New TransferOptions
            objTransferOptions.TransferMode = TransferMode.Binary
            objTransferOptions.FileMask = "*>=1D"
            Dim objTransferResult As TransferOperationResult
            objTransferResult =
                objSession.PutFiles("D:\*", "/", False, objTransferOptions)
            ' Throw on any error
            objTransferResult.Check()
            ' Print results
            For Each transfer In objTransferResult.Transfers
                Console.WriteLine("Upload of {0} succeeded", transfer.FileName)
            Next
        End Using
        Return 0
    Catch ex As Exception
        mobjFileWriter.FileWrite(ex.ToString)
        Return 1
    End Try
End Function
Thanks in advance for you support!
