Need help with deleting file from server
marleymar
First time WinSCP use, I've created a script to remove files from an FTP server. I'm using a batch file to apply the script to multiple servers, the problem is the batch is only applying the script to the 1st server listed. can someone take a look at my batch code to see if I am missing something?
Thanks!
@echo off
"C:\Program Files (x86)\WinSCP\WinSCP.com"
  /log="C:\Users\trainee\Desktop\CrestronFW\ResultsDelete.log" /loglevel=-1 /ini=nul
  /command^
    winscp.com /script="C:\Users\trainee\Desktop\CrestronFW\FWremove.txt" /parameter ftp://anonymous:anonymous%40example.com@10.1.105.17/
    winscp.com /script="C:\Users\trainee\Desktop\CrestronFW\FWremove.txt" /parameter ftp://anonymous:anonymous%40example.com@10.1.105.25/
    winscp.com /script="C:\Users\trainee\Desktop\CrestronFW\FWremove.txt" /parameter ftp://anonymous:anonymous%40example.com@10.1.105.33/
    winscp.com /script="C:\Users\trainee\Desktop\CrestronFW\FWremove.txt" /parameter ftp://anonymous:anonymous%40example.com@10.1.105.46/
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Re: Need help with deleting file from server
You are trying to call WinSCP from WinSCP. That cannot work.
It should be like:
winscp.com /log="C:\Users\trainee\Desktop\CrestronFW\ResultsDelete.log" ^
  /loglevel=-1 /ini=nul ^
  /script="C:\Users\trainee\Desktop\CrestronFW\FWremove.txt" ^
