c# transfer files in parallel
Komatozzz
Rus
Hello ewary one.
I have a problem with transfer files in parallel. When i do that - this look all ok, but indeed nope. If i start one task - File's transfer worked OK, but if i try do more then 1 session in parallel - session.FileTransferProgress in all Task return 100%, but File's loads in not all session in fact. What wrong i do?
PS Without parallel - all works fine.
await Task.Run(() => Parallel.ForEach(storeList, store =>
        if (store.CheckBox == true)
            parallel_options.CancellationToken.ThrowIfCancellationRequested();
                options.HostName = store.IpForFiles;
                session.Timeout = TimeSpan.FromSeconds(10);
                session.FileTransferProgress += SessionFileTransferProgress;
                session.Open(options);
                Console.Write("\n" + store.Num + " START!");
                try
                    foreach (var path in FilesList)
                        bool fileExists = session.FileExists("test_for_upload/");
                        if (fileExists == true)
                            var transferResult = session.PutFiles(path.PathFile, remoutePath);
                            Console.Write("\n" + store.Num + " EXISTS");
                        else
                            session.CreateDirectory("test_for_upload/");
                            Console.Write("\n" + store.Num + " CREATER");
                    Console.Write("\n" + store.Num + " FINISH!");
                    session.Close();
                catch (Exception err)
                    MessageBox.Show(err.Message);
                finally
        else
Re: c# transfer files in parallel
Show us your SessionFileTransferProgress, and add some logging to it. And show us an overall console output of your code.
Hi, Martin!
Thanks for the help, I took a closer look at the log file from SessionLogPath and found the problem.
Although I'm in the line options.HostName = store.IpForFiles; I set the host for the connection - it happens on a different ip.
Solved the problem with this
lock (session.SessionLogPath)
    session.Open (options);
Now everything works out correctly.
