Host Name Change all at once?
HWitche
New York
I have around 100 sessions with the same host. And now the name changed.
Is there a way to change the name for all sessions at once or do I have to change each one individually?
Thank you for your advice.
Hans
Reply with quote E-mail
HWitche
New York
Hi Martin,
thank you for your reply.
Now I'm fighting with the command prompt:
C:\Programs_installed>winscp.exe /batchsettings * HostName
'winscp.exe' is not recognized as an internal or external command,
operable program or batch file.
I'm doing something wrong, but what?
best
Hans
Either run the command in WinSCP installation folder, or use a full path to WinSCP.exe, like:
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /batchsettings * HostName=new_host
