WinSCP sFTP not working with imported public keyfile
chrigo
I tried connecting to an sFTP-Server, that needs a certificate installed on the client. I did this in Filezilla, and everything works fine. However, same public keyfile and credentials do not work in WinSCP.
Is there any special requirement for WinSCP?
Sc,
Chrigo
Re: WinSCP sFTP not working with imported public keyfile
Sorry, this is confusing. Certificate or private key? WinSCP does not support certificates with SSH/SFTP. I believe that FileZilla does not either. Regarding private keys: WinSCP and FileZilla support the same keys (they use the same SSH code). Can you post some logs? What exactly did you do?
