Problem with moving files from remote folder to local folder
rbylnz
Hello everyone!
I am creating a script that will help me do the following:
1. Copy files from remote folder A to local folder B.
2. If transfer (step 1) is successful, move files in remote folder A to local folder C. (archive folder)
If transfer (step 1) is unsuccessful, move files in remote folder A to local folder D. (error folder)
I do not have any problems copying the files (step 1). I am having trouble performing the move operation. I am trying to use the Session.GetFiles method within a loop, as you can see in the code below. I get no errors, but I see that nothing is moved. I would appreciate any help or suggestion.
$period = [TimeSpan]::FromSeconds(20)
$lastRunTime = [DateTime]::MinValue
while (1)
    while ((Get-Date) - $lastRunTime -lt $period) {
        Start-Sleep -Milliseconds 5000
        Write-Host "Waiting for new files..."
    $lastRunTime = Get-Date
    try
        # Load WinSCP .NET assembly
        Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
        # Setup session options
            HostName = "BLABLABLA"
            UserName = "BLABLABLA"
            Password = "BLABLABLA"
            GiveUpSecurityAndAcceptAnySshHostKey = "true"
        try
            # Connect
            # Set transfer options
            $remotePath = "/usr/BLABLA/REMOTEPATH/"
            $transferOptions.TransferMode = [WinSCP.TransferMode]::Ascii
            $transferResult = $session.GetFiles("/usr/BLABLA/REMOTE PATH/*.txt",
                "C:\Users\BLABLA\LOCALFOLDER-A\", $False, $transferOptions)
            $transferResult.Check()
            foreach ($transfer in $transferResult.Transfers)
                if ($transferResult.IsSuccess)
                    # Download success message
                    Write-Host ("File {0} was downloaded successfully..." -f $transfer.FileName.TrimStart("/usr/BLABLA/REMOTE PATH/"))
                    $FileName = $transfer.FileName.TrimStart("/usr/BLABLA/REMOTE PATH/")
                    $A = (get-date (get-date) -UFormat "%Y-%m%-%d %H:%M")
                    Add-Content C:\Users\BLABLA\LOCALFOLDER-A\Log\LogFile.log "$FileName | $A | Downloaded"
                    #MOVE OPERATION IS HERE: (REMOTE TO LOCAL-B (ARCHIVE FOLDER))
                    $transferResult2 = $session.GetFiles("/usr/BLABLA/REMOTE PATH/*.txt",
                       "C:\Users\BLABLA\LOCALFOLDER-B\", $True, $transferOptions)
                elseif (!$transferResult.IsSuccess)
                    #MOVE OPERATION IS HERE: (REMOTE TO LOCAL-C (ERROR FOLDER))
                    $transferResult3 = $session.GetFiles("/usr/BLABLA/REMOTE PATH/*.txt",
                        "C:\Users\BLABLA\LOCALFOLDER-C", $True, $transferOptions)
                    # Download error message
                    Write-Host ("Error downloading file {0}!" -f $transfer.FileName, $transferResult.Failures[0].Message)
                    $B = (get-date (get-date) -UFormat "%Y-%m%-%d %H:%M")
                    Add-Content C:\Users\BLABLA\LOCALFOLDER-A\Log\LogFile.log "$FileName | $A | Download error", $transferResult.Failures[0].Message
        finally
            # Disconnect, clean up
            $session.Dispose()
    catch [Exception]
        Write-Host ("Error: {0}" -f $_.Exception.Message)
    Start-Sleep -s 10
Re: Problem with moving files from remote folder to local folder
Your logic seems strange. Why are you downloading the files twice? That's a waste of time, bandwidth and your server resources.
Anyway, what is definitely wrong, is that you trigger the second download of all files for each previously downloaded file. Do it only once. Most of your code that is within foreach ($transfer in $transferResult.Transfers) should be outside of it.
Though, that does not explain, why no file is moved. If you need a help with that, we need a session log file.
